I tried DvdReMaker but it copies both sides on 1 disk as separate disks with DvdReMaker start menu to play disk 1 or 2. DVDShrink will combine without menus and DvdFab merges but when you play back only shows first side with chapters and when it play to the end, starts 2nd side, doesn't show up as 1 continues movie.
I'm not a pro at re-authoring and only have a couple of movies like this. I was really looking for a program or easy method of combining the 2 sides (or disks) as 1 continues movie with menu, chapters and extras.
Any suggestions and please be kind to a newbie.
Thank you for all your help,
chas638
Is this what you're looking for?
Joining double sided DVDs:
http://all-star-computers.net/dvd2dvdr/joinclip.html -
That will get the movie as one title. You can later import the menu. Any extras on the second disc or flip side would be an issue unless a new menu is made.
Depending on the disc, you might be able to use the menu from the second one and make some adjustments with PgcEdit.
5.1 to 7.1 - eac3to? Or just duplicate the sides?
By Asterra in forum AudioReplies: 3Last Post: 20th Apr 2012, 06:03 -
Why are there black bars at the sides?
By pooksahib in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2012, 09:11 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
How to merge 2 DVD Audio disks (ISOs)?
By shutz in forum AudioReplies: 7Last Post: 24th Jul 2008, 00:02 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
