Hi,
I added my own subtitles from an .srt file to an existing DVD, using SubtitleCreator. The time when a subtitle should appear is correct in the .srt file, although, in the movie, when burnt, the subtitles appear correct in the beginning, but they get delayed with more than 4 seconds in the end ( 2hrs12minute movie ). Any help on this?
I assume it has something to do with the NTSC vs. PAL DVD format, ( isn't it the case that one of these two has les fps ? ).
Actually I'm quite a noob when it comes to DVD's and that kind of stuff, so I thought I'd ask it here![]()
Thanks in advance !
4 seconds in the end for a 2hrs12minute movie is not much. Could be a 'drop frame/non drop frame' problem (which should result in about 4 seconds difference per hour). I don't know if SubtitleCreator can adjust this difference.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Subtitle Workshop also allows you to change subtitle timings. It even allows you to sync subtitles that you added using timings from subtitles that already exist.
Chipsndukes
mencoder subtitles disapper when -ss added
By bluenote73 in forum SubtitleReplies: 0Last Post: 27th Sep 2011, 16:18 -
With PgcDemux demuxed subtitles can't be added to mkvmerge
By Julian_evil in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2011, 00:19 -
Added Subtitles not sunchronize using SubtitleCreator
By ihmcjacky in forum SubtitleReplies: 8Last Post: 23rd Sep 2008, 08:08 -
Added subtitles to a dvd but want cant seem to get the original menu workin
By Loonatik in forum Authoring (DVD)Replies: 8Last Post: 9th May 2008, 05:31 -
Added subtitles too wide
By gnappa in forum SubtitleReplies: 12Last Post: 21st Apr 2008, 02:45
