Page 3 of 3
FirstFirst 1 2 3
Results 61 to 66 of 66
  1. Member iamtehsux's Avatar
    Apr 2008
    no i have not ive actually never heard of it until now.
    have you looked at the vob sample? do you think it would help on that?
  2. Originally Posted by iamtehsux View Post
    I only looked at the first one. FixBlendIVTC() did pretty well with it.
  3. Member iamtehsux's Avatar
    Apr 2008
    can you give me an example of how the avs setup would look for that sample?
    i think i have all the proper files/dlls for it now was just reading about it on the wiki page.
  4. Originally Posted by iamtehsux View Post
    The first was simple:
    import("C:\Program Files\AviSynth 2.5\plugins\FixBlendIVTC.avs")
    Mpeg2Source("VTS_01_1.demuxed.d2v", CPU=2)
    FixBlendIVTC()
    TDecimate()
    I just looked at the second it has a slightly different problem. This should work fairly well:
    Mpeg2Source("C:\Documents and Settings\John\Desktop\VTS_01_2.demuxed.d2v", CPU=2)
    Blur(0,1.0)
    FixBlendIVTC()
    TDecimate()
    Sharpen(0,0.7)
    FixBlendIVTC() has some options you can fine tune.
    <edit>
    I didn't think it would work right for the second clip, but the first script works fine with it. You don't need to use the blur/sharpen.
    </edit>
  5. FixBlendIVTC (and its replacement SRestore(omode="pp3")) was designed for telecined and blend deinterlaced (i.e., progressive) material . You don't have that here. It leaves behind interlacing, quite a bit of it. However, having said that, putting on a post-processor (Vinverse or TDeint(Full=False) seems to clean up most of it and give an acceptable result, something I didn't think possible when I first looked at it. Thanks!
  6. Weird. I swear there were no comb artifacts after FixBlendIVTC yesterday. But I went back and checked today and there is. I wasn't aware that SRestore supported this type of deblending -- thanks for that.
