Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 66
  1. you need the function srestore
    you can download the .avsi and put it into the avisynth plugins directory (avsi are autoloading, avs must be imported)
    http://avisynth.org/mediawiki/Srestore
    http://avisynth.org/mediawiki/upload/7/7d/Srestore.avsi
    read the instructions and docs, because there are required filters as well
  2. Except I've never had any luck autoloading it and the included doc says to import it:
    Use import("srestore.avs") in your script to load the function and use it like in the following examples.:
    It also gives the required plugins (as does the Wiki):
    needed plugins: - mt_masktools v2.0 (allways)
    - TIVTC v1.04 or higher (only for cache>0, not default)
    - RemoveGrain (only for double-blend-removal, not default)
    - Average (only for double-blend-removal, not default)
    So, a sample script might go:
    LoadPlugin("C:\Path\To\DGDecode.dll")
    LoadPlugin("C:\Path\To\MT_MaskTools.dll")#I may have renamed the DLL
    LoadCPlugin("C:\Path\To\Yadif.dll")
    LoadPlugin("C:\Path\To\TIVTC.dll")
    LoadPlugin("C:\Path\To\Average.dll")
    LoadPlugin("C:\Path\To\RemoveGrain.dll")
    Import("C:\Path\To\SRestore.avs")
    MPEG2Source("C:\Path\To\Test.d2v")
    Yadif(Order=1,Mode=1)
    SRestore(FRate=23.976)
    I load Yadif as a C Plugin. Others use STDCall. And don't try and autoload it. Read the doc for that one if it's not working. I don't autoload anything, but load what I need in the scripts.
  3. Member iamtehsux's Avatar
    Apr 2008
    does it matter what version of MaskTools2 is used? there's a lot of different ones on here wasn't sure which to get. http://manao4.free.fr/
  4. It's mt_masktools2 you want. I think I see only one, from Jan 28, 2006. I could easily be wrong, though. Try it out, open the script in VDub(Mod) and if there's an error message post it here along with the complete script if you can't figure it out.
  5. Member iamtehsux's Avatar
    Apr 2008
    thanks again manono i got it all working and all seems good
    might have another question for you though but gotta find the vobs first had some animated show that was pretty badly blended on some episodes wondered if it could be handled the same way.
    found it: http://
    i did some testing myself and it did look better using yadif/srestore but still had some ghosted/blended frames is there anything else i can try or is that probably the best I'm going to get with that source?
  6. Yeah, that one's a mess. It's also 23.976fps, but parts of it are hopeless. The part near the beginning with the man in the hat and trenchcoat can't be fixed. Virtually every field is blended. Other parts unblend fine.
  7. Member iamtehsux's Avatar
    Apr 2008
    dunno if anyone is still viewing this thread but could use some help again
    i am unsure about a certain source at first i thought it might need to be unblended and done at 23fps but now i think it might need to be done at 25fps.
    heres two vob sample:
    http://www.sendspace.com/file/
  8. You're in luck as it's not blended. If using TIVTC:
    TFM(0)
    TDecimate(Mode=0,Cycle=6,CycleR=1)
    If using Decomb:
    AssumeTFF()
    Telecide(Guide=2)
    Decimate(6)
  9. Member iamtehsux's Avatar
    Apr 2008
    thanks again manono.
    i was wondering about another set of dvds aswell i know they need to be done at 25fps but they still come out pretty badly blended in some spots is there any filters or any other way to clean them up a bit?
    heres a couple vob samples:
  10. Member iamtehsux's Avatar
    Apr 2008
    TFM(0)
    If using Decomb:
    AssumeTFF()
    Telecide(Guide=2)
    Decimate(6)
    using the tivtc method there was still some interlaced frames left in any other option that will remove them?
  11. Originally Posted by iamtehsux View Post
    Did you remove the link? I deleted it and can't get the same sample any more. Actually, that TFM(0) is a typo on my part as I meant to have only TFM(). Don't know if that'll make a difference, though.
  12. Member iamtehsux's Avatar
    Apr 2008
    fixed sample links. will test without the 0
  13. Originally Posted by iamtehsux View Post
    Did you get the field order right? The sample is BFF, but I don't know if the whole thing is BFF. A standard:
    Yadif(Mode=1)
    SRestore()
    seemed to do OK.
  14. For the earlier one, where the guys are walking through the jungle, I counted off 500 frames and didn't see any interlacing. If it happens, put on Vinverse after the IVTC to clean up any residual interlacing.
  15. Member iamtehsux's Avatar
    Apr 2008
    can you gimme an sample avs of how to use that filter incase i need it never heard of it before was reading about it on the script page and its a little confusing
  16. Member iamtehsux's Avatar
    Apr 2008
    for the one that needs
    Yadif(Mode=1)
    SRestore()
    should it be like this or leave it()
    SRestore(FRate=24.975)
    and yea im pretty sure the whole thing is BFF
  17. It's probably 24.975fps, but making it 25fps leaves some room for error. Up to you. You can look around to see if one gives better output (meaning fewer blended frames) than the other.
  18. Member iamtehsux's Avatar
    Apr 2008
    how would you handle this dvd? would you do it with yadif/srestore @23.976 or does it look like 24fps i was thinking the first but it doesnt really appear to be all that blended but looks more like 23fps to me then 24fps but the frame pattern is a little different.
  19. Separating the fields or bobbing it would show it's not fieldblended, so there's no need for SRestore. This looks like something from a TV show where fields were dropped to speed it up so they could stick in more advertisements. It has orphaned fields in it. Is this from a retail DVD, or from something made at home by someone? Anyway, I can't make it perfect, but try your luck with these or some variation of them:
    TFM()
    TDecimate(Mode=2,Rate=24.975,MaxNDL=7)
    #TDecimate(Mode=0,Cycle=88,CycleR=15,MaxNDL=7)#may be you'll like this better. I do.
    The second one is closer to the true framerate, but still has a few dupes, as well a a few dropped frames (common to both, because of the orphaned frames). It's not 23.976/24fps, but a much greater framerate, perhaps one derived from a PAL source.
  20. Member iamtehsux's Avatar
    Apr 2008
    Thanks again! and yea after some testing the second one did seem a little better
    but i was also wondering what is the best way to tell if an animated dvd needs to be ivtc'd or deinterlaced? some are easier then others if you can find a spot where every frame has movement but with the odd frame pattern of some its annoying.
    something like:
    or something like:
    i wasn't sure about the first 2 thought maybe deinterlace but the third looked like normal ivtc at first then frame pattern seemed to change. first 2 are from the same just different spots third is from something different.
    and then there's this:
    its not animated but wasn't quite sure how to handle the dvds probably one of the most badly mastered sets i've seen.
  21. Because parts of anime DVDs are sometimes progressive 30fps these days, if you run into one that's a mix of progressive 29.97fps and telecined 23.976fps, it might be better to encode it as VFR. Me, I would never just deinterlace something that wasn't shot using video cameras (and anime sure isn't).
    Samples 1 and 2 are just simple IVTC:
    Telecide()
    Decimate()
    Sample 3 is the same but because it was so incompetently done, I'd add Vinverse afterwards:
    Telecide()
    Decimate()
    Vinverse()
    The fourth one is the only interesting one. It's from a PAL source, but isn't field-blended. Try this on it:
    TFM()
    VinVerse()
  22. Member iamtehsux's Avatar
    Apr 2008
    what would be the best way to unblend this dvd do you think?
    http://www.sendspace.com/file/u6eylm
    I was also wondering if there is pal stuff mastered from ntsc dvds the same way theres so many ntsc dvds mastered from pal stuff? i will have to look for the dvds im thinking of but i remember having some pal dvds that looked kinda weird and pretty badly blended in some parts.
  23. Originally Posted by iamtehsux View Post
    Yes, lots.
    As for the sample, why the same-old same-old? RePAL or SRestore handle it fine.
  24. Member iamtehsux's Avatar
    Apr 2008
    thats what i thought just thought the video looked kinda jumpy in a few spots like a lot of dropped frames or something more then usual
  25. Member iamtehsux's Avatar
    Apr 2008
    was hoping someone here could help me again and didnt really want to make a new thread =)
    i have a weird blended ntsc dvd that i know needs to be encoded to 23fps, after looking at it i thought it would just need to be unblended but that didnt help at all and in some places it make it worse i think was a few spots with the jerky/jumpy playback like wrong frames were removed.
    Sample1: http://www.sendspace.com/file/uq1c1n
    Sample2: http://www.sendspace.com/file/vn5wxl
  26. You can forget about unblending that one properly.
  27. Member iamtehsux's Avatar
    Apr 2008
    how would you ivtc it? with just normal ivtc no unblending i still see some residual interlacing even with vinverse.
    i also have a question about this dvd, its a pal dvd but it looks like it was mastered from a ntsc source and pretty badly blended how would you handle it? i asked about pal dvds being mastered from ntsc once before but never ran into one until now.
    Sample: http://www.sendspace.com/file/wrava0
    and thanks for the quick reply manono didnt even take half and hour =)
  28. Are you saying those are samples of the retail Mad About You DVDs? Pretty bad. I was just reading some reviews of the DVDs and they all mention the very bad quality of the video. I wouldn't handle them. I'd send them to the recycle bin as soon as I had a look.
    For the PAL one:
    Yadif(Mode=1)
    SRestore()
    It has its own peculiarities, but except for some left over blends that seems to work OK.
  29. Originally Posted by iamtehsux View Post
    Did you try FixBlendIVTC?
