Greetings.
We have this LG RC195 it's about 3 maybe 4 years old.
In recent months it's starting to reject DVD's.
The message that appears on the screen says
"unknown disc. please check disc again"
This occurs even when we hire a DVD or purchase a brand new DVD.
Can anyone shed some light on this problem.
It's possibly just a dirty lens, you could try cleaning it. Otherwise, it is most likely failing. Time to get a new one.
Google is your Friend -
I've recently replaced the burner in that particular model with an PC IDE LG DVD writer. The original had a standard 40-pin IDE interface and 4-pin power connector. It connected to the mainboard via an adapter PCB and mini-flex cable.Originally Posted by mishon
Use the open/close function on the RC195 front panel or remote control, not the button on the burner itself. You'll need to remove the front facia of the IDE burner to make it fit inside the case. Use strong double-sided tape to mount it, and cable ties to hold it in place. Otherwise you could make up some brackets for a more professional installation.
Need Help with DVD/Vhs combo...
By shaytala in forum DVD RippingReplies: 12Last Post: 13th Sep 2010, 14:11 -
VHS to DVD Combo Machines?
By JXBlack in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Nov 2008, 11:12 -
VHS/DVD Combo Converter
By Evhmoon in forum DVD & Blu-ray RecordersReplies: 12Last Post: 30th Mar 2008, 23:17 -
Best DVD-Recorder/VHS Combo For The $$$???
By expat in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Dec 2007, 10:00 -
Magnavox DVD/VHS TV combo Hack Code...
By Tap_Artist in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2007, 16:58
