I have a avi file that was re-encoded with subtitles (There was an avi-video which was encoded again with subtitles)
i want to extract those subtitles and convert them into standard *.srt subtitle.
Is it possible?
Avi info:
Complete name : xxxx.avi
Format : AVI
File size : 349 MiB
Duration : 41mn 54s
Overall bit rate : 1 166 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 41mn 54s
Bit rate : 1 003 Kbps
Width : 624 pixels
Height : 468 pixels
Display aspect ratio : 4/3
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.143
Stream size : 301 MiB (86%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 41mn 54s
Bit rate mode : Variable
Bit rate : 150 Kbps
Minimum bit rate : 32.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 45.1 MiB (13%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 369 ms
Writing library : LAME3.98r
Encoding settings : VBR (mtrh)
You need an OCR software to be able to convert the burned in / hard subtitles from the avi. You can try AVISubDetector (and I think subrip also supports avi).
Converting avi + srt to mp4 with embedded subtitles
By zaphod_es in forum SubtitleReplies: 1Last Post: 13th Oct 2011, 16:48 -
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 07:35 -
.avi -> .flv with embedded subtitles using MENCODER
By the_provider in forum Video ConversionReplies: 0Last Post: 28th Oct 2009, 17:38 -
[INFO] Embedded subtitles in .AVI files
By Midzuki in forum SubtitleReplies: 0Last Post: 24th Jan 2009, 01:17 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
