hey guys
i recently bought a philips 722 dvd player to watch my dvd's and svcd's..
i haven't had any problems playing dvd's but when i play svcd's the screen freezes for about sec sometimes.. it seems to happen at ramdom.. sometimes a svcd will play fine for 30 minutes and than all of sudden freezes like 4 times in 3 minutes.. when i play the same svcd again it will play those same scenes fine but freeze at other scenes..
when i bought the player the guy from the store made it region free and i've used different types of cd-r media.
anyone familiar with this problem and is there a sollution?
thnx in advance,
Lev
Iīm losting hair with Philips too, mine is a 711 , but Iīve discovered :
1) When I encoded with Tsunami , SVCD template , the bug appears, play and freeze randomly.
2) When I encoded with CCE, MPG2 , the bug appears but not so frequentely.
3) When I encoded with Tsunami , VCD template , no problems, always play fine.
So , I conclude that is because Philips itīs SVCD creator and if U made a SVCD with SOFTWARE that isnīt full compliant with Philips specs, bad things may occur, but not with VCD.
I have Philips tools (designer,creator and tester) to make SVCD and when I create one using other tools,like VCDEasy or TSCV and use Philips tester to verify my SVCD , I get a lot of errors and warnings.
At last , after I upgraded Philipsīs DVD BIOS to version 7.22 (originally 7.12) , CCE MPG2īs stoped freezing but not Tsunami. -
CCE work OK for my Philips 622, but only if I don't go too low on bitrate. Examples :
CBR 2500 + 224 OK
VBR min 900/avr 1600/max 2500 OK
VBR min 900/avr 1400/max 2400 (352x576), 2 x audio 160+160 OK
VBR min 900/avr 1250/max 2000 (352x576), audio 128 DOESN'T WORK (Freezes) -
I've got the 711 Philips model, and I experimented problems with TMPEGenc mpg.
If I fastforward or review the player locks.
The firmware il 7.22
Does it happen to you?
Giuliano
dish dvr 722 external hd to pc
By desiking911 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st May 2011, 13:21 -
Help with Philips MCD119 problem
By SteveHarrison1 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Sep 2010, 17:07 -
Philips DVP3980/37 Problem
By Renegade in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Mar 2009, 01:54 -
Problem with Philips DVP 5980/12
By Tinah in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Dec 2007, 12:57 -
Problem writing to Philips dvd-r.
By jackrussell in forum MediaReplies: 0Last Post: 13th Jun 2007, 06:41
