I'm new to FCE. I've got a video that I made a .jpg Intro/Outro for in Photoshop. The background of the .jpg is black. When I save the video in FCE as a Quicktime movie the bottom 3/4's of the intro/outro have a slight grayish hue. I have no idea where that came from.
Anyone have any advice on how to fix that or what could be causing it?
Thanks,
-Jess-
sounds like the dimensions of the jpg do not match the dimensions
of the project, and the gray at top and bottom is garbage matte
that has been applied to fill the area that isn't jpg.
What is default setting for your project?
ie. 720 x 480, 640 x 480, etc.
Your .jpg in Photoshop should be sized to that dimension.
Open up Photoshop, create new document,
select from the presets what the size needs to be that
matches your project, click ok.
the resulting canvas is the size it needs to fill to make the
jpg look right."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
but it's only noticable when viewed at a certain angle on my screen. It became much more pronounced when in the movie.
Connecting PC To HDTV Newb Question
By pr0bation in forum Newbie / General discussionsReplies: 14Last Post: 14th Dec 2010, 18:29 -
Sorry for the NEWB question. Edit DVD.
By MPTech in forum Newbie / General discussionsReplies: 2Last Post: 25th Oct 2010, 18:50 -
New newb with old question
By Madzir55 in forum RestorationReplies: 4Last Post: 17th Jan 2010, 12:05 -
Newb Capture Help/Question
By sheblom in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 11:42 -
another simple question about FCE and iDVD... =)
By ednarophati in forum MacReplies: 1Last Post: 31st Jul 2007, 10:15
