anybody has the same symptoms..
i believe ie8 should be faster than ie7 in terms of start so what is going on?
any fix available?
	Do you use Spybot? There's apparently an issue with Spybot's immunization for IE clashing with IE8, causing slow startups. (Or any other software which might add a lot of entries to the Restricted Sites list.) If cameras add ten pounds, why would people want to eat them?
	Use Firefox or Chrome. Want my help? Ask here! (not via PM!)
	Tools > internet options > advanced tab > hit the "reset" internet explorer button down below.
 Try again ... problem is common.
  IE8 logs me off after I close the browserBy jyeh74 in forum ComputerReplies: 1Last Post: 24th May 2011, 09:03
  IE8 - unable to view drop down lists. Help!!By thegeeman in forum ComputerReplies: 4Last Post: 18th Aug 2010, 11:01
  Problems with IE7 and IE8By Gabriel in forum ComputerReplies: 5Last Post: 12th Jun 2010, 12:31
  IE8 website cookies removed after each rebootBy Nintendo Fan in forum ComputerReplies: 13Last Post: 2nd Mar 2010, 22:48
  Download Youtube / ASF etc. stream using IE8By p_uriel in forum Newbie / General discussionsReplies: 4Last Post: 8th Dec 2009, 07:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
