I have some VOB files(e.g. VTS_01_1.VOB, VTS_02_1.VOB, ...).
The VOB files are created by a sony DVD camera.
I want to add a simple menu and creat a DVD without to re-encode the VOB video files.
Is there any tool to do it.
I used "GUI for dvdauthor", but it makes "Inconsistent timecodes" error on some VOB files.
Please help me.
				Results 1 to 9 of 9
	Use VOB2MPG to extract the video and audio from the VOBs without re-encoding, then author with these. Try DVD Styler instead for authoring. Read my blog here.
	Try importing the VOBs into DVD Styler, however DVD cameras were not meant for people who want to do anything with their footage except watch it off the disc they recorded it on. MPG files cannot contain subtitles, so anything that extracts the video and audio will lose the subs. Those you will have to extract manually using a subtitle ripper, and put back in during authoring. I suspect the timecodes issue comes form the stop-start nature of camcorders. The only tools I know of that may fix that don't work on VOB files. Read my blog here.
	I think it is a very simple task to just add menu to some video files (without re-encoding).
 I have tried many tools loke nero, DVDLab, FixVTS, VobBlanker, DVDflick and ..., but non of these do the correct job. Some tools remove subtitles and some encode the file and so on!
 Do you have any idea about TMPGEnc_DVD_Author?
	In addition to menus, IFOs and BUPs need to accompany the VOBs. If you want to create a working DVD with a menu from what you have, you'll need to follow guns1inger's advice. There are no shortcuts. No program can figure out what to do by looking at the VOBs alone.Originally Posted by temp759
	...but it makes "Inconsistent timecodes" error on some VOB files.
 This is just a warning, the resulting DVD may be fully ok, but there is no guarantee. You can try it nevertheless.
 Other possibility:
 Demultiplex the vob files and use the elementary streams in GfD. If you have ifo files for your vob files, use pgcdemux. Otherwise try projectx. You should get the video (m2v or mpv) audio (wav, ac3 or mp2) and subtitles (sup) in separate files which can be imported in GfD. Then the streams should be 'clean' (no inconsistencies).GUI for dvdauthor:
 https://www.videohelp.com/~gfd/
	Hi, I would suggest using the following guide:
 https://forum.videohelp.com/topic120021.html
 Also, look at my recent posts (advanced search for author btodorov) as I had to solve similar problem with one of my recovered DVDs.
 Regards, BT.
  How to encode a DVD/VOB to a vfr mkvBy kwanyeung in forum Newbie / General discussionsReplies: 13Last Post: 1st Aug 2011, 10:56
  Joining VOB-files without having to re-encodeBy FallenAngelII in forum EditingReplies: 2Last Post: 28th Jul 2008, 10:01
  creat dvd to fit your tv screenBy projecttemp in forum Video ConversionReplies: 2Last Post: 16th Jul 2008, 08:37
  Converting PAL VOB FILES TO NTSC VOB FILES...By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
  .VOB to DVD - Do I have to re-encode?By WuTangDvD in forum Video ConversionReplies: 5Last Post: 18th Feb 2008, 01:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
