Results 1 to 9 of 9
  1. I have tried EVERYTHING on the net concerning the removal of the Acronis loader fatal error. On booting my computer, I get an error that says the boot drive (partition) is not found. I then have to press enter for the computer to boot from the normal operating system. I removed Acronis from my machine and nothing I do will get rid of this error. Even doing everything Acronis told me to do (plus many of things) it still happens. Has anyone ran into this problem and found a fix for it?
  2. Have you tried
    FIXMBR C:
    FIXBOOT C:
    BOOTCFG /rebuild
    Originally Posted by jagabo
  3. It's been too long stiltman, I've forgotten how to get around in basic. Unless there is a program that I could use, I'm pretty well lost. In the process of moving and all my discs are in storage so I can't use the OS disk for XP.
    canada
    Try this method,its not that hard to do.
    http://support.microsoft.com/kb/289022
  5. johns0... Thanks for the reply. I did as instructed on your link and the ONLY thing different from their example is the last command (noExecute=Optout). Being a little gun-shy I thought I would ask if this might be the problem. Following is a copy of the line from my ini file.
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Home Edition" /fastdetect /NoExecute=OptOut
    Edit... That didn't work, same old problem. I hate to think about it but it looks as if a format C: is just over the horizon.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Sounds like acronis did a boot folder setup,best to do what stiltman suggested,just read how to do it,its just a command line you can paste the info in.
  7. Originally Posted by Captain315
    edit:
    OOOOPPPSSSS.....didn't read the part about not having your OS CD....
    OK, find someone that has any version of XP on a CD...Doesn't matter if it's Home/Pro etc.
    Put in your XP CD and boot from it
    Choose R for recovery console
    Enter the number for your XP installation (usually 1)
    Enter admin password
    Run the three commands at the command prompt in the order I listed
    type exit to reboot
    Basically, you're doing the old DOS/win9X command of "fdisk /mbr" but for XP
    You're rebuilding the master boot record
    BTW, my instructions are form memory, so getting into the recovery console might be a little different, but you get the idea. Oh and this can NOT be done from a cmd prompt within XP...Has to be from a seperate boot method. XP's CD being the easiest
  8. Thanks stiltman... I will find a copy and give it a try. Hope that will fix the problem. I appreciate the help.
  9. Did what you suggested stiltman but it was to no avail. Now I'm in the process of restoring all my programs. Does anyone know of a disk cloning software that's easy to work with and doesn't mess with your bios and such like Acronis did? Would appreciate and suggestions.
