hello,
i have an axxo movie (688x280)
This movie has black bars.
i want to cut the bars with vurtualdub cropping.
But i see no black bars in virtualdub.
wat can i do?
i hope you can help me
gr
THen it doesn't have any black borders. The software player may add borders if you play it in FULL screen or if it contain soft subtitles .
But axxo movie? sounds like downloaded warez crap. -
688x280 is about a 2.45:1 aspect ratio assuming square pixels. It should have black bars when viewed on a 4:3, 16:9, or 16:10 display.
oke but i have a 'normal' tv no widescreen.
do you have an idea what can i do to get no bars ?
gr -
Crop half the picture away or squish it to fit.Originally Posted by Cowabunga
Or use the zoom function on your divx dvd player...if it has any then...
Or buy one of these: http://www.lifeatmost.com/tv-and-display/philips-cinema-219-ultra-widescreen-lcd-tv/
Why are there black bars at the sides?
By pooksahib in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2012, 08:11 -
Back to the black bars
By Joolz2020 in forum Newbie / General discussionsReplies: 7Last Post: 19th Feb 2011, 08:02 -
Adding black bars
By ebay in forum Video ConversionReplies: 4Last Post: 7th Aug 2010, 04:37 -
Black Bars
By cinnamonhearts2 in forum Newbie / General discussionsReplies: 15Last Post: 30th Jul 2009, 12:44 -
Need to cut off black bars
By Dozza in forum EditingReplies: 8Last Post: 2nd Sep 2007, 07:17
