Just got a JVC miniDV camera with DV output,after i capture the video (DV-AVI) to my pc i cant convert it to mpeg2 in 16:9, only in MP4 i can do this, even that the video is shoot in 16:9 from the camera itself
i use AVS video converter
any recommendations or is there anything i do wrong?
regards
Use a better mpeg2/dvd converter like for example the free hcenc or an all-in-one solution for it like FAVC or AVStoDVD.
Or use other good mpeg2 encoders like tmpgenc xpress, tmpgenc plus, mainconcept reference, cinemacraft encoder basic. -
it works, yes it's far better
but i feel like the DV AVI have better frame rate or quality -
Check your encoding settings. The bitrate and motion compensation settings on your MPEG-2 encoder might not be set correctly. For whatever tool you are using, check for online guides and forums for optimal settings.
Best is subjective, but WinDV is very good and what I use.
DVIO is also good but doesn't have a preview window. It can sometimes work better on older machines.
Scenalyzer is another free option (older version)."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
Newbie: Bluray movie to AVI/MPEG2 conversion and SPECS
By BIFFtheSTIFF in forum Blu-ray RippingReplies: 2Last Post: 25th Feb 2010, 17:38 -
AVI to MPEG2 Conversion Software
By cyberboy in forum Video ConversionReplies: 3Last Post: 7th May 2009, 20:54 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 06:04 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42
