I have an AVI that the file size was a little too big so I used AVI-Mux_GUI-1.17.8 to cut off a few minutes, but after doing this, the file size was reduced by more than the proportion of time cut off. My question is: Why does AVI-Mux_GUI cut the file size? Will this reduced file size reduce the picture quality? It seems to me that simple editing should not alter the parameters of the video. Following first screenshot is of original AVI and second screenshot is of AVI edited with AVI-Mux_GUI.
	No, it can't convert. Have you tried played it so it's really 1:58:09 minutes? And try cut with avidemux or virtualdub and see if it's the same size.
	Yes, the edited version seems to play fine with Media Player Classic and is 1:58:08. I haven't tried to edit with any other program yet.
  AVI-Mux GUI problemBy toni-boy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 23rd Oct 2010, 13:37
  Question: MKV File Size vs MP4 File SizeBy VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44
  AVI-MUX: How do I mux avi file with a setting of "preload=512?"By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10
  Question about avi file size limit for DVD playersBy jimdagys in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Dec 2009, 04:12
  Alternative to AVI-mux GUI?By badreligionhead in forum Video ConversionReplies: 3Last Post: 8th Dec 2009, 13:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
