I have some .avi files that when i try to burn on toast 10 to dvd it askes if i want to convert to NTSC. so i click yes to do so and it takes an hr to burn the avi file to dvd and its not readable on dvd player. i tried converting to mp4 but toast does the same thing it takes an hr to burn is that a normal time and im just tripping or am i doing something wrong. come on fellow mac users help me out i cant figure out y the dvds wont play.
Moving you to our MAC section.
Does the burned dvd work on your mac with a dvd software player?
Are you using CRAPPY dvdr media that wont work on your dvd player? See www.nomorecoasters.com -
I would author the disc first, saving to a Disc Image first,
and then try opening that on the mac and playing with DVD Player,
as Baldrick suggested. If the Mounted Disc Image plays fine
in Apple's DVD Player, then burn that to disc. If not,
then you'll need to make adjustments.
You'll also need to post back specs on the avi if we are to help you further.
Open the avi in Quicktime Player, and perform a "cmd-i" and
post back the info provided in that window so we can determine
if it is a codec issue, size issue, etc that might be causing problems
with Toast encoding the file to DVD (Mpeg-2)."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Urban Mac User -
Cruz240sx, follow terryj's advice and create the disc image first. Also, unless these are short movies it should take much more than an hour for Toast to do the conversion. And be sure to have the Perian codec installed (www.perian.org) or you may end up with video that has no audio.
It will help if you describe the AVI's specs. -
there were times it wouldn't work and all i'd get is a generic error message, and after waiting several hours at times i tried a different approach...Originally Posted by terryj
AVI do DVD (Video TS) on Mac
By TilenH in forum MacReplies: 3Last Post: 30th Jun 2011, 16:28 -
AVI TO DVD - MAC OS X
By westerndevon in forum MacReplies: 7Last Post: 15th Jan 2011, 15:02 -
Convert a dvd into an AVI file(s) on a mac
By shonmader in forum MacReplies: 2Last Post: 15th Jun 2009, 09:34
