I do not have a firewire port on my laptop so i bought a cable to adapt from usb 2 to firewire. how can i get this to work? my capture program vegas 8 does not see my camera. can't find drivers for firewire.
Can you get your money back? I hope so. The cable you describe converts the DV to MPEG1. The quality is terrible and the camcorder is invisible to Windows - by that I mean DV-based software can't see it. According to the blurb for the cable, you have to use their proprietary software to capture and edit. Their advertising seems to be deliberately confusing/misleading.
It is actually cheaper to buy a PCMCIA FireWire card (that slots into the side of your laptop) than the cable.John Miller
Firewire and USB 2.0 Cable quality - does it matter???
By tarrickb in forum Capturing and VCRReplies: 21Last Post: 29th Mar 2012, 13:59 -
What firewire cable do I need?
By Jedi5 in forum MacReplies: 3Last Post: 7th Sep 2011, 17:17 -
Samsung micro USB-B to USB-A cable
By luigi2000 in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2011, 15:05 -
Firewire to usb 2.0 cable
By zanos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Aug 2010, 13:28 -
Camcorder - Firewire to USB cable
By geek2330 in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2007, 10:29
