  1. hi there, anyone know how to convert mov to vcd ??
    I tried to use xing Encoder but sometimes it's work and sometimes it isn't work!!! help please!!!!
  2. .mov files have severa security features put in them. This will only allow you usually to convert the video to another format with no audio. To get audio you just need to use a microphone of some type that will allow you to record the audio while it is playing. Then you would have to combine the audio and video together and try to make it sync. Basically, if your .mov is protected in that way, it isn't worth the time or the trouble.
  3. thank's mrtubbles! but Is There any software to cracks the security on the mov files?
  4. use rad tools it will convert mov to avi with sound it is direct copy of sound and you choose codec when conversion starts it lets you choose it then have fun
  5. thank's shadowdog! where can I get this tools anyway? thank's!!
    Jun 2001
    Silver Spring, MD USA
    I'm not sure what you guys have replied is exactly the truth .. or was previously a problem, but I'm sure most everyone else knows there's a MOV plug-in for TMPGEnc ... no need to convert to AVI first, audio remains in tact. You can find a resource for this plug-in on the Tools page of this site.
  7. I have a copy in my yahoo folder the program is in the converter folder it it the easy way to convert to avi
    http://briefcase.yahoo.com/freenight0062001
    just install rad tools then open it select the file do not hit play hit convert a file at bottom left the second screen pops up till you get better with rad tools just go to upper right coner click convert file the codec screen comes up then select the codec and watch how fast it converts the file
    have fun
