This is my 4th post,I want to shrink a movie dvd into a 4.5GB dvd and I only want movie in it.excluding menu etc etc. Is it possible to do that??will that be playable in stand-alone players?
ALSO
I've decrypted only the movie VTS file,is it possible to create a dvd out of it.If yes then how?
Hit the reauthor button - Then read the guides over to the left.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Simplest method is to do a Movie Only decrypt with DVDFab HD Decrypter, then use DVD Rebuilder or DVD Shrink to make it fit.
If you have already grabbed the entire disc, open it in DVD Shrink, click on Re-Author, then drag the title(s) you want from the right-hand pane to the left-hand pane. Then click Backup to create a new disc structure.
It depends how you did it, and what files you have. If you have IFO/BUP and VOB files then you have essentially done what I described above - a movie only rip. if you don't then you may have to re-author from scratch with an authoring tool, or you may have useless garbage.I've decrypted only the movie VTS file,is it possible to create a dvd out of it.If yes then how?Read my blog here.
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
how to shrink a movie to fit a dvd 5?
By just in forum Newbie / General discussionsReplies: 2Last Post: 29th Oct 2008, 23:58 -
Shrink DVD movie
By Bookmaster in forum EditingReplies: 3Last Post: 24th Dec 2007, 06:41 -
Tutorial: Using DVD Shrink to extract ONLY THE MOVIE
By RogerTango in forum User guidesReplies: 3Last Post: 11th Dec 2007, 21:35 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59
