I got this new samsung sc-hmx10 which has the files in the .mp4 format. i was trying to edit the files (simple triming) in the provided cyberlink powerdirector 6. but after i trim the file when i try to save it i only get the option "save project" or "save project as" and the file gets saved as some .pds file. i want to save the edited file again as .mp4, how to do that? i am novice with these, please help !
thanks for your reply. but i didnt get what you said, please explain in simple terms, sorry i am new to these things..
do you mean that powerdirector cannt save in the same mp4 format after editing? then in what popular format it can save n how to do that? -
sorry in powerdirector terms you have to "produce" a new file. click produce and set it up to save in whatever format you want as an end result, it doesn't have to be mp4. mp4 isn't a format you want to edit/re-encode more than once.
you might give avidemux a try for simple trimming and see if you can set the video and audio to copy and format to mp4. use the slider/a button/b button at the bottom to trim beginning/end. it would be a lot faster than pd6.
Audio problem with Cyberlink PowerDirector.
By GangstaRap in forum EditingReplies: 4Last Post: 20th Dec 2009, 00:06 -
Cyberlink Powerdirector 6 mkv question
By rubius316 in forum EditingReplies: 1Last Post: 13th Jun 2009, 10:32 -
I have a question about cyberlink powerdirector 6.
By ingeborgdot in forum Authoring (DVD)Replies: 4Last Post: 3rd Nov 2007, 22:31 -
Fed up with Cyberlink Powerdirector - Can you help me choose something else
By gayclarke in forum Authoring (DVD)Replies: 5Last Post: 9th Jun 2007, 23:09
