Hi all, seemed the most appropriate place to post this
This week I shall be upgrading to new PC and also from XP to Vista, i use VirtualDubMod a lot in the video editing I do and I hear various opinions on how compatible VDM is with Vista, have done some googling and still am none the wiser, so I am hoping some people hear can clear it up for me.
Coincedentally use it only to extract the audio from video files, rather than serious editing with it, not sure if that will make any diference, if it wont work it wont work i guess...
Worst comes to worst and is not possible, any recomendations for an alternate software to remove audio from Mpeg2 files accuratly as VDM would be greatly appreiciated
Thankyou in advance![]()
" Who needs Google, my wife knows everything"
VD Mod works fine with Vista.
I have used it for a couple of years. If you have Vista 64, then it's a bit more problematic. But there is a VD for V64 available.
VirtualDubMod works fine under Vista. But you may have a little trouble installing some codecs for use with it.
well as i said i generally only use Mpeg2 video, but the option to import xvid or .264 would be nice, if not essencial.
thanks for info tho
what codecs cause issues??
fixing <i> tags while encoding (VDM) - [solved]
By NeoTrix in forum SubtitleReplies: 0Last Post: 22nd May 2010, 14:24 -
VDM Crashes with FFDShow Encoding
By adalect in forum Newbie / General discussionsReplies: 13Last Post: 28th Apr 2010, 17:01 -
VDM Won't Encode to MP3
By adalect in forum Newbie / General discussionsReplies: 41Last Post: 24th Apr 2010, 00:52 -
AVISynth Templates in VDM
By adalect in forum Newbie / General discussionsReplies: 2Last Post: 19th Apr 2010, 21:39 -
HandyCam > PC > VDM! Big problem!
By ChezDigital in forum Video ConversionReplies: 26Last Post: 23rd Jul 2008, 22:23
