Hello Guys,
I have a whole bunch of mod files (25) I that I recorded off my camcorder, but I need to get the audio only off it. I am lost because all I can find are useless trail software that do not help me. I've tried to look for a guide but none are available. Also, I need to edit the audio as well, in terms of removing parts, how can I do this?
Thank you very much
Results 1 to 11 of 11
Most camcorder mod files are mpeg2 video with ac3 audio
Editing as a wave file is more editing friendly than mp3 or wma
You can use vdub with the mpeg2 plugin or avidemux
In vdub, file=>save wave
In avidemux, audio=>save (this will just stream copy the audio instead of re-encoding it). Note you can encode it to mp3 by changing the audio sidebar to "mp3" instead of copy
A free audio editor is audacity. To remove parts, you could select and press delete
All these tools are free -
Thank you very much!!!!
Now another question, I was doing the recording for a group project, so thats why I have 25 bits. Now if I wanted to join them to have a seemless audio, how would I do this?
Thank you! -
^yes in some versions, I think that auto append feature was broken. It works fine for sequentially numbered files in 2.4.4 (just tested it)
Just curious, how are yours sequentially numbered?..
MOV020.MOD
MOV021.MOD
MOV022.MOD
etc..
This sequence is not working for me..." Who needs Google, my wife knows everything" -
Figures it be that simple, thanks...
@OP sorry for the hijack....
Hey Guys,
I'm using the program that you said to use (avidemux), and I appended all the files! However, when I am saving the file, it doesnt allow me to save as audio....the only options are save as video or save as bmp, jpeg... I selected save as video and specified audio.mp3 but it is also saving the video....
I changed the option for Audio to MP3, the video is set as COPY and format is AVI.... sigh helllp
audio (top menu)=>save
It will save it as whatever you set the audio sidebar to (e..g copy, mp3, pcm wav etc..)
or cnrl+alt+s
Convert expired WMA to MP3
By pchan in forum AudioReplies: 4Last Post: 20th Jul 2011, 09:44 -
wma to mp3
By rjc7394 in forum AudioReplies: 5Last Post: 14th Sep 2010, 14:00 -
Is it possible to convert Mp3 to wma?
By t_jay17 in forum AudioReplies: 8Last Post: 17th Feb 2009, 16:32 -
Converting mp3 to wma with Vegas 6.0
By solarblast in forum AudioReplies: 2Last Post: 1st Oct 2007, 06:50 -
wma to mp3
By rjc7394 in forum AudioReplies: 0Last Post: 8th Jul 2007, 19:28
