Hello,
I have got a Sony DVP NS-700 DVD player at home (PAL). I just got a NTSC DVD movie and funnily, when I put it to the player, it just says "disk not playable". I tried to read the various postings in this forum but couldn't find a definitive answer to the question. Also I can't find adequate product information from Sony sites :(
If the player cannot play NTSC disk is there any reasonable way to convert it to PAL? The vobs can be ripped yes etc, but is there any simple way to change the frame rates et cetera and make it PAL version...
I also noticed, that the disk plays fine in my PC. Could it be a ifo/bup problem?
PS It is NOT a region problem, since the DVD player is region free and the dvd as well.
Short reply by myself. After trying and trying, I finally found the answer.
I recreated the IFO/BUP files, which didn't have any region information at all (hmm). Ifoedit did the trick, I just added all the regions to it :)
Pehu
DVD Player Converts PAL to NTSC
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2011, 19:56 -
Playing PAL DVD on Philips DVP3345V and NTSC TV.
By atarmiga in forum Newbie / General discussionsReplies: 6Last Post: 14th Feb 2009, 20:31 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 18:19 -
NTSC/PAL DVD player
By jonas more in forum DVD & Blu-ray PlayersReplies: 24Last Post: 9th Jan 2008, 08:40
