I can´t hear any sound when I am editing files with TMPGEnc DVD Author. Is it possible to hear the sound of the clips while editing?
	Are you using version 1.6? Then you need the ac3-plugin if it's ac3 audio, see https://forum.videohelp.com/topic331981.html#1743745
  Tmpgenc dvd author 3 will not author my m2v files????By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10
  Sound turned to white noise when using TMPGEnc Xpress & DVD AuthorBy Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03
  TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 15:53
  difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
  TMPGenc DVD Author 3 Sound ProblemsBy wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
