  1. Hello,
    I recently started using Ulead Media Studio Pro 6.0 to edit VCD compliant mpeg files. After I get the clip exactly the way I want it, I go to create my file and the output is really jerky or perhaps a better way to phrase it would be stuttering...My source file is mpg...my output is mpg....but something is taking place during the editing process that keeps returning this jerky result.
    Any ideas?
    Thanks in advance.
    Canada
    If it's anything like VideoStudio then it doesn't create standard (compliant) (S)VCDs.
    You may have to demultiplex and (re)multiplex with TMPGE. Try it, it might work.
    Allan
