Eeek have I stuffed up? I just encoded a bunch of flv's & mp4's (Youtube etc) to DVD using HC Encoder, and I've just realized that HC is set to "Interlaced TFF"! Should I have set it to "Progressive"?![]()
Probably, but what was the framerate of the source? And is the Moon NTSC or PAL?
Buy My Books -
Hehe, yep. If PAL 25fps or NTSC 29.97fps, no problem. If NTSC 23.976fps, then it makes a difference and they should have been encoded as progressive with pulldown applied afterwards.Originally Posted by gadgetguy
Ah ok thanks, I think I may be ok. The stuff I've already encoded have been 25fps clips. I'm encoding to DVD to play on my analogue TV.
I'm using some pretty heavy-duty avisynth filtering and encoding can take up to 24 hours, so I was panicking when I realized I had encoded as "interlaced", but I think it's all OK. -
Encoding progressive video in interlaced mode will result in a little unnecessary blurring and artifacting of the chroma channels. You probably wouldn't even notice if it wasn't pointed out to you.
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 09:22 -
Progressive and Interlaced Chroma -- again!
By Anonymous344 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Apr 2011, 07:14 -
de-interlaced means progressive ?
By codemaster in forum EditingReplies: 19Last Post: 23rd Dec 2010, 06:08 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 16:41 -
encode interlaced material witth ffmepg to MPEG2 but get progressive output
By Massa in forum ffmpegX general discussionReplies: 9Last Post: 13th Jan 2009, 12:42
