Is it just me, or does TMPGEnc not shut down Windows XP? I'm referring to when you batch encode, you check to shutdown when done. Under Win98 it would shutdown the whole pc, which was great because I could leave a long conversion running overnight and it would turn the pc off. But since I upgraded to WinXP, it just shuts tmp down but not Windows/pc. Is it just me?
I run WinXP and the latest version of TMPGEnc (2.52) and it shuts down Windows just fine.
Ok if anyone is still following this topic, I've figured it out. Under WinXP, if you only have one user setup, then Tmpgenc will shut your system down upon completion. But if you have multiple users setup like I did, it will exit Tmpgenc but doesn't shut the system down. I went down to 1 user and now it shuts down fine.
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
Power Shut Down Issue
By Snakebyte1 in forum ComputerReplies: 11Last Post: 6th Dec 2010, 06:50 -
[SOLVED] TMPGEnc DVD Author doesn't like VBR??
By Taeran in forum Authoring (DVD)Replies: 5Last Post: 19th Sep 2008, 18:11 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Telling McAfee to Shut Up
By ahhaa in forum ComputerReplies: 9Last Post: 23rd Aug 2007, 18:13
