Results 31 to 52 of 52
That's what I first tried to do (MakeMKV + Handbrake) ...
1 (big) problem: Handbrake cannot "read" the subtitles from the mkv created by MakeMKV !
Not everyone has english mothertongue and watching US/UK-movies only! (I speak French and I like US, German and Asian movies! And I hate dubbed movies!)
Any solution? (I'm on Mac)Thanks!Bruno, 30
Brussels, Belgium -
how do i put the Film preset in the presets window?
what are the settings or how do i create a preset or find the preset to add? -
I've used Baldrick's guide how to shrink mkv file and everythig went fine very first time. Size got decreased from 18.6GB to 8.13GB. It let me keep 2 audio tracks and Eng. subs. Only problem was not visible total running time while playing new mkv with VLC player. It was easy fix with running new mkv through mkvmergeGUI.
But whole process took almost 9 hrs...Last edited by konik111; 4th Oct 2011 at 09:30.
Oh my...
Of course converting using Handbrake took almost 9 hrs.
Remux using mkvmergeGUI was only like 3 min.
Sorry for not precise post
Hi guys,
First off, thanks to the original poster, this was a very friendly guide. I have a BDMV folder which contains an entire bluray's content. First, I demuxed using tsmuxer and got a h264 video file, a dts file and a sup file. I then muxed them usig mkvmerge, and my plan was to shrink the size using Handbrake.
The problem is that the mkv file has slow video and lasts about twice as much as the original content. I did check the original FPS which are 25, but specified it in mkvmerge anyway, so I don't know what else could be wrong.
Any ideas? Here are mediainfo specs of one of the m2ts files and the resulting mkv, just in case it helps for suggestions.
Thanks!
Uploaded with ImageShack.us
Uploaded with ImageShack.us -
I just realized the problem may have originated when demuxing, as the 264 file that resulted from tsmuxer lasts about 4h50m, more than twice of the original Here is Mediainfo on the 264 file:
General
Complete name : \\PCH-A200\share\Download\VANESSA PARADIS ENCODE\00000+00001+00013+00015+00016+00017+00018+0 0019+00020.track_4113.264
Format : AVC
File size : 30.5 GiB
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Bit rate mode : Variable
Maximum bit rate : 33.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced -
Hi Baldrick,
Great guide you have here. Just wondering if you know or anyone on here knows what is the best software to convert MKV to iPad?
I've been using 'ImToo iPad Video Converter 6' but sometimes the video and audio go out of sync and the frames per second seems to be reduced.
Thanks,
Adam Lowe. -
Make a new thread instead of answering in this thread. https://forum.videohelp.com/newthread.php?do=newthread&f=18
Maybe I am doing something wrong but I installed the app and the only thing I see here is a big button. There is nothing else to do but to click this big button to start with. So, when I click it, the message I receive is that "this functionality is shareware, you may evaluate it for 30 days, blah blah...".
When I downloaded from the official site, I could not find any indication that this is shareware, on the contrary, all info says that features are free (while in beta).
I would say that, unless I am doing something wrong, you are misleading people into believing this is freeware. It is not. I can't do anything without "starting my trial period".
I have nothing against shareware apps, I do have a lot against misleading people into wasting time installing something that is NOT what it is wanted. I want a freeware solution to my problem and if I can't find one, no problem, I can live with it.
Please, update the info about your app. It is shareware, not freeware.
By the way, my blu-ray is not encrypted, so your app was not supposed to decrypt it, still, can't do it because it is shareware. -
It is Shareware...but also free while in beta. The key is updated on the forum page:
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
bad start for a first post. don't dig up old threads for your own purposes. start your own thread. don't whine. ask for help nicely. you don't even say what software you are complaining about. if perhaps it is by some off chance makemkv, then go to the page that link takes you to and read it - CAREFULLY. it is currently free while in beta development.--
Thank you!
Why doesn't the author make it clear in the front page of his app? Why do I have to dig deep into forum posts to find this out? Doesn't make sense (answering to the post above).
I just dislike shareware apps that try to hide the fact that they are shareware. I am tired of installing "freeware" apps just to find out that they are not free at all. -
The best... mmh i dont think so
The easiest of course but in my chapterEditor you find the "multi-editions-editor"(mee) and you have a bit more control about the resulting mkv.
(cutting, trimming, chapter naming, track order ...)
But the most advantage is:
You can keep a BD with multiple editions of the move in 1 mkv file with the corresponding chapter.xml and tags.xml.
Im not sure, but i think makemkv isn't able to create such multi-edition-mkv's.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
Blu-ray remux (.mkv) to Blu-ray structure again ?? how
By Trigarr in forum Authoring (Blu-ray)Replies: 1Last Post: 20th Oct 2011, 09:44 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 23:58
