Hey all,
I have a subtitle and it ends is .LHN
Now my question is how can i convert this file to a known format? (such as srt,ssa,sub etc)
Thanks 8)
Results 1 to 10 of 10
Welcome rotembal
Its not a subtitle yet ... You have to know something about file compression ... try unpacking it first with
http://www.softpedia.com/get/Compression-tools/Universal-Extractor.shtml -
Hey m8,
Thank you for your reply.
It seems I can't unpack it..
this is the error msg I get:
Try LHarc or 7-zip, maybe WinRAR. The file extension conforms to no known subtitle format, the LHN extension is listed as a compressed file format. Unless someone is just screwing with you.
You could try viewing it with Notepad, possible some idiot just changed the extension for some unknown reason. -
HI,Originally Posted by Nelson37
I THINK that you missed something let me give you some background.
There is a fight between 1 subtitles group http://www.qsubs.co.il in Israel & one site http://www.torec.net
because of this fight the subtitles group (QSUBS) decided to release there subtitle in encrypted format LHN
the only way to watch movie with this format is to install specific software that uses vob.
so we are the viewers stuck in the middle of this fight & can't watch movies in dvd's streamers etc.
the only way to see movies in dvd's & streamers is to re encode the movie that we download & "to plant" the subtitle.
example for one subtitle in this format:
http://www.sratim.co.il/movies/subtitles/download.aspx?mid=73000&n=2056250923&ID=166513
that's the story...
AnonymousGuest
Hey rotembal
Check this website for ur unknown extension.
http://filext.com/index.php -
The "subtitle" file in the link is a standard SRT subtitle file, lots of players will handle that.
Now I am confused as to the problem. "special player to handle VOBs?".
Does the linked file contain readable language, or is it scrambled somehow? If that file is readable to you, then I don't understand what exactly the issue is. -
My guess is that what dumdum1945 means is that they have to install a special software player that understands the encrypted subtitle format that Qsubs is now using.Originally Posted by Nelson37
Converting .mkv to .avi subtitle problems?
By oxadiba in forum SubtitleReplies: 1Last Post: 9th Apr 2011, 10:45 -
Xvid4psp 5.0 problem converting .mkv to .avi with subtitle
By Conrad007 in forum Video ConversionReplies: 3Last Post: 13th Jan 2010, 15:15 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 15:17 -
converting a subtitle to english?
By php111 in forum Newbie / General discussionsReplies: 10Last Post: 14th Aug 2007, 08:20 -
converting subtitle file to plain text?
By shenacat in forum SubtitleReplies: 1Last Post: 2nd Jun 2007, 17:16
