Hi guys,
I've been transcoding 1080p and large 720p MKV's to DVD-5 sized 720p MKV's to save hard drive space as well as make it possible to burn them onto DVD-5 discs. Unfortunately however, I seem to always get choppy video when doing this, which is especially obvious in panning shots. Converting a DVD-5 to a dvd-resolution MKV does not give choppy results. The problem lies not with playback, I believe, since the original 1080p video plays fine without chopping.
I'm using AutoMKV 0.98.4, but I had the same results with AutoMKV 0.98 (which is why I tried updating to 0.98.4).
Underneath you find the log for one of the videos that gave choppy results. The original frame rate according to the frame rate indicator of VLC is 23.976 fps.
If anyone could help me out, I would greatly appreciate it. I only just registered here, but I've solved several issues and problems already in the past half year or so by reading some of the very interesting and helpful threads here, so I'm hopeful that I'll find the help I need.
Note that I'm not including audio in the final file. This is because I want to keep the original audio as often as possible, and AutoMKV doesn't seem to like that when dealing with HD files. I just add the audio afterwards with MKVMerge. If anyone knows a solution for that as well, that'd be great, but it's not really that important since muxing it afterwards manually works quite okay.
Code:16:45:22 0.98.4 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 16:45:22 Selected Input file: G:\Finished\video\video.mkv 16:45:22 Selected Output dir: F:\Temp\video\temp\ 16:45:22 Selected Final Name: video 16:45:22 Selected Container type: MKV 16:45:22 Selected Encoder: X264 16:45:22 Selected Size: 1020 / 1 16:45:22 Selected Profile: 2_Pass_Better_Quality.xml 16:45:22 Selected Resizer: SimpleResize (neutral soft) / 1280 16:45:22 Selected Filters: RemoveGrain(mode=2) 16:45:22 Selected Deinterlacer: AUTO 16:45:22 Selected Field Order: AUTO 16:45:22 Track Language 1: NONE 16:45:22 Audio Codec 1: Copy Original 16:45:22 Track Language 2: NONE 16:45:22 Audio Codec 2: Copy Original 16:45:22 Activate Anamorphic Encoding 16:45:22 16:45:22 Extracting audio track 0 NONE with ffmpeg 16:45:23 Unable to determine movie properties , switched to DirectShowSource 16:45:54 Number of Frames: 61463 16:45:54 Framerate: 23.976044 16:45:54 Movie length in Seconds: 2564 16:45:54 Movie Width/Height: 1280/720 16:45:54 Number of Frames: 61463 16:45:54 Framerate: 23.976044 16:45:54 Movie length in Seconds: 2564 16:45:54 Movie Width/Height: 1280/720 16:57:06 Source is declared tff by a margin of 52/41. 16:57:06 Advanced Deinterlace Routines Log 16:57:06 Analyzed 257 sections of five frames 16:57:06 Found Interlace Sections: 0 0.00% 16:57:06 Found Progressive Sections:257 100.00% 16:57:06 Found Telecined Sections: 0 0.00% 16:57:06 Found Zero Mov: 100.00% 257 16:57:06 Found One Mov: 0.00% 0 16:57:06 Found Two Mov: 0.00% 0 16:57:06 Found Three Mov: 0.00% 0 16:57:06 Found Four Mov: 0.00% 0 16:57:06 Found Five Mov: 0.00% 0 16:57:06 The Movie is declared to progressive 16:57:06 Starting X264 16:57:06 Command Line 1' Pass X264: E:\Setup Files\Video & Burning\AutoMKV\AutoMKV0984\exe\encoder\x264.exe --pass 1 --bitrate 3329 --stats "F:\Temp\video\temp\.stats" --ref 1 --progress --keyint 250 --bframes 5 --qpmin 10 --qpmax 51 --no-psnr --filter -1,-1 --subme 2 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me dia --no-ssim --level 4.0 --b-adapt 2 --b-pyramid --partitions none --threads auto --thread-input --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.0:1.0 --sar 29491200:24883200 --output NUL "F:\Temp\video\temp\movie.avs" 16:57:06 Command Line 2' Pass X264: E:\Setup Files\Video & Burning\AutoMKV\AutoMKV0984\exe\encoder\x264.exe --pass 2 --bitrate 3329 --stats "F:\Temp\video\temp\.stats" --progress --keyint 250 --bframes 5 --qpmin 10 --qpmax 51 --no-psnr --mixed-refs --trellis 1 --ref 4 --filter -1,-1 --subme 6 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --level 4.0 --weightb --b-adapt 2 --b-pyramid --partitions p8x8,b8x8,i8x8 --8x8dct --threads auto --thread-input --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.0:1.0 --sar 29491200:24883200 --output "F:\Temp\video\temp\movie.264" "F:\Temp\video\temp\movie.avs" 18:44:47 Finished 1' Pass X264 20:24:09 Only Movie Size: 1066878272 bytes 20:24:10 "E:\Setup Files\Video & Burning\AutoMKV\AutoMKV0984\exe\matroska\mkvmerge.exe" -o "F:\Temp\video\temp\video.mkv" --default-duration 0:24000/1001fps --track-name -1:"video" --aspect-ratio -1:1.777778 "F:\Temp\video\temp\movie.264" --title "Done with AutoMKV 0.98.4 http://forum.doom9.org/showthread.php?t=140178 " 20:25:04 Final Muxed size: 1067427328 bytes 20:25:05 Encoding finished: 01:40:18 elapsed time 20:25:05 ----------------------------------------------------------------------- 20:25:05 Script AutoCrop.log 20:25:05 20:25:05 Crop(0,0,1280,720) 20:25:05 ----------------------------------------------------------------------- 20:25:05 Script movie.avs 20:25:05 20:25:05 #loadpluginstart 20:25:05 20:25:05 #test1 20:25:05 20:25:05 #importstart 20:25:05 20:25:05 #test2 20:25:05 20:25:05 movie = directshowsource("G:\Finished\video\video.mkv",fps=23.976044,convertfps=true,audio=false) 20:25:05 movie = isRGB(movie) ? ConvertToYV12(movie,interlaced=true) : movie 20:25:05 movie = isYUY2(movie) ? ConvertToYV12(movie,interlaced=true) : movie 20:25:05 function getOrder(clip c) { 20:25:05 order = GetParity(c) ? 1 : 0 20:25:05 Return order } 20:25:05 #filter1start 20:25:05 20:25:05 #test3 20:25:05 20:25:05 last=movie.Crop(0,0,1280,720) 20:25:05 fixed_aspect = 1.777778 20:25:05 out_width = 1280 20:25:05 #Aspect_Error = 0.000% 20:25:05 out_height = 720 20:25:05 #resizestart 20:25:05 20:25:05 #test4 20:25:05 20:25:05 SimpleResize(out_width,out_height) 20:25:05 #filter2start 20:25:05 20:25:05 #test5 20:25:05 20:25:05 RemoveGrain(mode=2) 20:25:05 20:25:05 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - -
Simplest way to convert 1080p h264 mkv to 720p mkv?
By aer in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2011, 11:16 -
1080p vs 720p MKV Files
By esabet in forum Newbie / General discussionsReplies: 15Last Post: 24th Dec 2010, 20:27 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35 -
Best quality option to convert 1080p mkv to 720p mkv
By carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 08:17 -
25fps 1080i mkv convert to 24fps 1080p or 720p mkv?
By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 10:57
