hi, what exactly wv and how do i convert it from wav to wv ?
Results 1 to 11 of 11
What exactly is WVOriginally Posted by pcb
Sorry but English IS my first language..... -
WV = West Virginia.Originally Posted by pcb
Not many waves there but many low mountains.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
just found out
so what should i use to convert from wav to wv ?What is WV?
WavPack is an open source lossless audio coding algorithm with floating point data support and optional lossy audio compression. -
FLAC is pretty much the standard form of lossless compression so not sure why one would want to fool around with anything else IF lossless compression is the goal.
FLAC website ---> http://flac.sourceforge.net/
Please note that FLAC is also open source and therefore free.
You could also try TTA, Shorten, ALAC, WMAL, APE, etc.
"Choice is yours, don't be late."
thanks for all suggestion
having problem with command line with wavpack but manage to do it with
foobar2000
Thanks again for all your help guys
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
Convert flac or wav to lpcm
By wiseant in forum AudioReplies: 7Last Post: 30th May 2012, 19:02 -
Convert X to Y directly or X to WAV then to Y?
By videohalp in forum AudioReplies: 5Last Post: 8th Sep 2008, 02:05 -
how can we convert ac3 to wav?
By sumeshkri in forum AudioReplies: 6Last Post: 4th Sep 2008, 03:29 -
How to convert .vob to .wav?
By showmi in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2008, 13:27
