  1. AdrenalineWomenGunsCars mrjust's Avatar
    Sep 2008
    is their any cable or wires that would allow me to watch my .avi on tv without encoding?
    like to connect from computer to tv?
  2. You haven't supplied us with enough info. What type of outputs does your computer have and what type of inputs does your tv have? If both have hdmi or dvi than that would be the way to go.
    Feb 2008
    It depends on your video card and what connections your TV has.
    Most middle range / high end video cards will have a s-video output for standard analog televisions.
    If you have a HD set, the TV might have a VGA or DVI input you can connect the computer to.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Or you could spend a whole $40.00 on a standalone dvd player that will play avi (as in Divx/Xvid) files from a dvdr/cdr on your TV without re-encoding but then you were not real specific on your "avi" files specs.
  5. AdrenalineWomenGunsCars mrjust's Avatar
    Sep 2008
    Noahtuck
    Posted: Apr 11, 2009 21:55
    what dvd player would you recommend? so i have to burn the .avi directly to dvdr or cdr and im set?
    my .avi are movies download from the internet.
    SPECS: mpeg-4 visual , streaming video@L1 (got info from MEDIAINFO)
    Philips, Walmart, $60-ish
    Those specs don't mean anything to me, try Gspot.
  7. Member darkknight145's Avatar
    Feb 2007
    Australia
    Or you can get a DVD player (that can play DIVX/MPEG4) with a USB connector on the front panel, just copy your .AVI to a USB drive and then plug the USB drive into the DVD player, the DVD should be able to play it to the TV.
  8. AdrenalineWomenGunsCars mrjust's Avatar
    Sep 2008
    lordsmurf
    PostPosted: Apr 12, 2009 22:33
    THESE IS THE SAME VIDEO
