Looking at the title, you would think I am on about capturing. I am not. I was watching a DivX I had converted from one of my DVD's on my PS3, there was a lot of jerky movement. So I look at the original DivX file using VirtualDub and noticed it wasn't the PS3 jumping, that was how it had been encoded. I set it at quantizer 4, and pretty much all default settings, yet every so often, jerky movement. Tried it both in VirtualDub and TMPGenc 4 Xpress. The source file doesn't have this problem, yet the outputted DivX is jumping in the same places. Anyone had this problem before? I am using codec version 6.8.5.
Thank you guys
We want information, Information, INFORMATION.
What did you use to to do the conversion? What settings beside quantizer=4 did you use? Was the source interlaced and if so what did you do about it? Was it 24 f/s converted to 25? Worse yet 30 to 25?
The codec is not the problem (unless there is a bug in that version), the process is. Four does seem a bit low to me but I used Xvid when I did h.263 and it wouldn't cause jerky movement in any case.
What do you mean by jerky? One stutter every 24 frames?
Ethelred -
Interlaced 25fps > interlaced 25fps. I ticked the boxes Interlaced and TFF. Rewatching it, it seems to be just fast motion where frames are been dropped. I can understand this happening while playing, but why encode it that way too?
My understanding is that DivX and XviD are not well suited to interlaced encoding and although it is possible to do so it rarely works well.
Found the problem. If I change it from Home to Unrestrained, it plays perfect. Dunno why but it does?
Jagabo, please do not reply to this post. Thank you.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 12:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
Please help me stop dropping frames!
By justin81 in forum Capturing and VCRReplies: 28Last Post: 1st Apr 2011, 08:17 -
WinDV dropping frames
By 2Bdecided in forum Capturing and VCRReplies: 3Last Post: 17th Oct 2009, 04:23 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 16:06
