I am new to encoding and wondering if I am getting speeds in line with my set-up, or something is amiss. I am using Vista 64, and my processor is a mildly overclocked Q6600. I am trying to turn a 45 minute documentary into an AVI file. Steps I followed: First I used ripit4me to get it onto a folder in my drive. From what I can see that program automatically runs decrypter as well. Then I started up autoGK. At first I decided to encode by size, selecting a 700mb file. I started my encode at about 1 am last night, at 11 am this morning it was still going and only 35% done. I felt something but have gone wrong, so decided to start over using a new encoding option. I set it to encode for 75% quality. About five hours have passed and I'm at 9%. Are these the kind of speeds I should be getting and, if not, does anybody have an idea what the source of the problem could be? Thanks for your input.
Something's wrong. A 45 minute video done using the Target Quality setting of AutoGK probably shouldn't have taken more than 20-30 minutes at most. I don't know for sure what's wrong but would guess that there are background things going on. Do a CTRL-ALT-Delete and check what other processes are taking up CPU cycles. Cut down on the stuff loading when booting up. Make sure there aren't any virus's or spyware stuff hogging your computer. Others around here know more about those things than I, though.
Thanks, manono, for confirming my suspicions something was wrong!
I could not find anything using my processort but AutoGK, so I decided to start fresh: I rebooted, reripped the video, and now, thankfully, everything seems to be moving forward at a much more reasonable rate!
Still not sure what caused that problem though...
Some encoding questions
By inject0r in forum Newbie / General discussionsReplies: 14Last Post: 30th Apr 2012, 11:47 -
Handbrake Encoding Questions
By x22 in forum DVD RippingReplies: 1Last Post: 19th Oct 2011, 21:41 -
Encoding noob questions
By Frakit in forum Blu-ray RippingReplies: 8Last Post: 3rd Jul 2010, 02:08 -
A few questions on Anamorphic encoding
By scubasam in forum Newbie / General discussionsReplies: 10Last Post: 31st Mar 2010, 22:04 -
Encoding questions
By helper in forum Newbie / General discussionsReplies: 4Last Post: 3rd Nov 2008, 23:58
