I made an AVI from a large number of JPGs using WindowMovie Maker.
Now, I'd like to add, insert other pics into that AVI. The WMM project has been inadvertently deleted.
Is there a way to revert the AVI back into JPGs without losing quality or doing frame freeze?
Thanks a lot for any help.
Virtualdub, open avi, File->Save image sequence.
avidemux, open avi, file->save->save jpg images.
And you will just get the "quality" that the avi video contain. So if you had high resolutions jpgs and made a low resolution(or highly compressed) avi you will just get the low resolution quality. -
Thanks a lot gunslinger and Baldrick.
Just occurred to me another alternative to avoid loosing picture quality.
What if instead of reverting the AVI back to JPGs, I just insert the new JPGs into the existing AVI?
Is there a way to do this?
How to convert jpg pics to avi?
By pmolson in forum Video ConversionReplies: 24Last Post: 22nd Oct 2014, 17:50 -
mp3 + jpg -> avi/mp4/mkv?
By disgust in forum Video ConversionReplies: 10Last Post: 22nd May 2012, 11:25 -
embedding jpg into avi, xvid files
By pheonix rising in forum EditingReplies: 0Last Post: 14th May 2011, 14:54 -
Making an avi from jpg, bmp or png files
By cabs46 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2009, 07:14 -
How do I join JPG images to creat an AVI file
By forensic in forum EditingReplies: 9Last Post: 15th Mar 2008, 22:23
