I could not think that this was too difficult.
I have search every video application I could find and none seems to be able to do this, I just could find 3 turnarouns but none of them please me.
I need to record myself playing my doublebass along with GarageBand backin audio. My setup is, MiniDv cam to record video, Mackie audio interface to record audio and GarageBand to play the backing tracks. To do this I find 3 ways:
1.- Record Video in QT and audio in GarageBand. Then export both recordings and sync them in iMovieHD (perhaps it can be done in QT also).
2.- Use a screen video capture app (they all seem to be able to record external audio and system audio). Open QT, GarageBand and the screen capture app, select just the video window in QT with the screen captura app. Then start the 3 apps record and stop the 3 apps.
3.- Use an app called wirecast that allows to record video and external audio while it plays any audio file loaded into the app. While this is very goos it has two drwbacks. The app is 400$ and there is no way to mix the final output (both audio get mixed in the recording).
Is there another way I can do this?
Please easy of use is mandatory. I use it to record myself practicing, so I can't stop after each recording and loose time in the computer.
Results 1 to 1 of 1
How do I: Record Video, Audio from MIC, AND Audio playing from speakers?
By miimaster2 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 20:51 -
How can i record audio from a you tube video
By robotica71 in forum AudioReplies: 6Last Post: 17th Mar 2008, 21:42 -
Video Gone Audio There - after moving 400GB off of HD to External HD
By zicman in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2007, 07:08 -
How to record a video with external mic using the computer?
By Captain Satellite in forum Newbie / General discussionsReplies: 10Last Post: 10th Jun 2007, 14:03 -
How can I display video/audio my external monitor???
By Hal05154 in forum DVB / IPTVReplies: 2Last Post: 24th May 2007, 13:28
