hey guys,
how can i make rar files from a mpeg. When i do this, i get the rar files but no exe file.......what do i wrong??????
which options do i have to use in winrar???
thanx!
Read the help file that comes with winrar; it explains it well.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
here's What I do.
with winrar installed, right click on file to compress it. select "add to archive". the options I choose are.
-split to volumes 15,000,000 bytes
-i use "old style volumes"
-if you want an .exe file instead of .rar, select sfx archive.
that should be all
i also check;
-put recovery record
-put authenticity verification
not sure what they do, so i check em anyway!'
hope that helped. of course if you only want one big rar file, ignore the split to volumes.
TA69
files .rar
By marlo in forum ComputerReplies: 13Last Post: 14th Jun 2009, 05:57 -
.rar files
By deadman1972 in forum ComputerReplies: 10Last Post: 26th Aug 2008, 11:37 -
rar files w no pars
By rotuts in forum MacReplies: 2Last Post: 8th Aug 2008, 22:30 -
How do I burn .rar files and other
By cinemanetwork20 in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2007, 10:48 -
Problem with RAR files
By crowheart in forum Newbie / General discussionsReplies: 16Last Post: 15th May 2007, 00:49
