A newbie's question but I cannot find the answer from the forum. I have DVD MPEG-2 files with two audio streams, audio 1 is the song and audio 2 is the karaoke. I want to swap the two audio streams so that the file is played with karaoke first. Is there a way to do this quickly? I have a lot of files to convert.
Thanks in advance.
Billy
Can you do it? Yes. See this guide:
https://forum.videohelp.com/topic338721.html
However, this is for adding new subtitles but you can still use the guide. Use method 2 and just skip the subtitle specific stuff. Swap the audio files when you re-author.
Can you do it quickly? No.
If you have "a lot of files to convert", it will take a long time. After you get used to the procedure, I'd guess that it will take you 30-60 minutes per DVD to rip them, make the changes and then re-burn them.
Is playback of mpeg-ps streams possible on a pc?
By craig198 in forum AudioReplies: 2Last Post: 26th Apr 2011, 12:12 -
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
MPEG TS Streams missing LFE channel ?
By s1lenc0r in forum AudioReplies: 3Last Post: 17th Apr 2010, 10:20 -
Swap Replace Audio in MPEG4-AVC without recompress
By cele_82 in forum EditingReplies: 2Last Post: 17th Jan 2010, 04:09 -
Audio Stream Swap in WMV video files
By a1s2d3f4 in forum Newbie / General discussionsReplies: 17Last Post: 15th Sep 2008, 11:57
