What is the optimal Windows resolution for viewing 720p and 1080 MKV videos?
For example, if I'm watching a 720p video .... do I need to set Windows resolution to 1280 X 720?
Same question for watching 1080 videos...do I need to set Windows resolution to 1920 X 1080?
I have tried changing resolution for different videos, but don't notice any difference in quality.
BTW, I have my HDTV connected to PC via PC/VGA port (worked better for me than DVI-HDMI). My max resolution is 1360 X 768 due to the VGA port limitation, which is fine by me.
Thanks.
Leave Windows at your monitor's/TV's native resolution. If you set Windows to some other resolution the monitor/TV will resize the frame back to its native resolution anyway. So you can't avoid a resizing.
Well, you might find minor differences depending on which scales better -- your graphics card or your TV.
How to downscale 1080 to 720?
By Catinaz in forum Video ConversionReplies: 3Last Post: 30th May 2010, 20:19 -
Problems playing MKV 720 & 1080 - Not enough PC ?
By NotSoEasy in forum Software PlayingReplies: 8Last Post: 7th May 2010, 12:30 -
The old question about 720/1080, but for mine :)
By Paul Iddon in forum DVB / IPTVReplies: 4Last Post: 17th Mar 2010, 11:43 -
How do I know if my .MKV's are 1080 or 720?
By Dschultz in forum Newbie / General discussionsReplies: 2Last Post: 22nd Mar 2009, 22:32 -
1080 vs 720
By WuTangDvD in forum DVB / IPTVReplies: 27Last Post: 5th Oct 2007, 19:20
