I recently purchased a Panasonic HDC-SD9 High Definition video camera. Love it!!
The software that it comes with it is ok but kind of lame and not that stable.
I've read that Corel VideoStudio Pro X2 is good software but it crashes alot.
I would like to be able to import many different files types including the high definition format that the camera outputs which I believe is MTS, and output in either High Definition or DVD format. Ohh, easy to use also.
Any suggestions would be greatly appreciated![]()
Joe
Just my 2 cents.
Sony Vegas Movie Studio Platinum Pro
http://www.sonycreativesoftware.com/moviestudio/compare -
Thanks Soopafresh. Is the software fairly easy to use or do you have to be a pro to use and understand this software?
Just my 2 cents. -
I use Vegas Pro and find it far more flexible than Premiere and similar software. However, as with any software purchase, the best option is to try the demo for yourself. Interface and workflow must suit the way your brain works. The last thing you need to be doing is fighting the software to get results. The software should be a tool that you can just pick up and swing as necessary, without having to puzzle over.
Yes, there will always be a learning curve, and video is complex stuff. The higher up the software chain you go, the more complex it becomes. But if the software and your brain are in sync, the curve is much more gentle, and you become productive much faster.
Only by using will know if this is true for you.Read my blog here.
Which video editor software for the Panasonic HDC-TM90?
By hmbleservant in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Aug 2011, 10:19 -
Which editing software for the Panasonic HDC-TM90?
By hmbleservant in forum EditingReplies: 1Last Post: 6th Aug 2011, 23:20 -
Suggestions on video editing software
By Grunberg in forum EditingReplies: 11Last Post: 22nd Jun 2011, 20:39 -
Panasonic HDC-SD60 video artifact
By abeelandig in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 27th Jul 2010, 16:52 -
Automated video editing software, suggestions.
By x2x3x2 in forum EditingReplies: 14Last Post: 18th Jun 2010, 02:37
