I've been having a few problems with HD playback; seems like I can play some 720p videos but some others slow down, while audio seems to work fine. Also, 1080p don't seem to work either, they behave the same way.
I keep getting the 90-100% peaks on CPU activity
I could be wrong as I don't really know much on specs but they seem good enough:
Operating System: Vista Home Premium SP1
CPU Speed: AMD Turion X2 Dual Core Mobile RM-72
RAM Memory: 4 GB
Video Card: ATI Mobility Radeon HD 3450
I'm using K-Lite Codec pack; I can also provide info on the files I've been trying to play.
Anyone has any ideas on what's going wrong?
On a final note, as a newcorner, I have a few slightly off-topic questions:
1- Is it okay to say the names of files, even if they were obtained through warez? I read the rules topic and it doesn't say anything about that.
2- How come some files have the ".720p" on their names, although if I check them with MediaInfo, the resolution isn't really 720p?
3- Is K-Lite Codec pack good? I seem to hear a lot more about CCCP...
	So you're saying that if I uninstalled K-lite and use FFd and Haali on their own it should be better?
 K-lite does come with FFD, Haali and MPC Home Cinema.
	Humm, so what should I do at this point? Remove K-Lite and do as Baldrick said or just keep it?
	At this point, I'd leave it alone unless absolutely necessary. Your HD playback issue is likely either codec or cpu related. As Baldrick noted, ensure you have the latest version of ffdshow and haali media splitter installed and playback using MPC Home Cinema. But otherwise, it sounds like you don't have enough cpu. Google is your Friend
  Couple of getting-started questions about HD editing, playbackBy android25ua in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2011, 15:08
  questions on popcorn hour tv playbackBy arconreef in forum Media Center PC / MediaCentersReplies: 8Last Post: 12th Nov 2010, 21:35
  Random DVD Chapter Playback & Other Authoring QuestionsBy houstono in forum Authoring (DVD)Replies: 18Last Post: 18th Jul 2009, 09:43
  Pinnacle 11 - playback issues on DVD - rapid playback problemsBy crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19
  Playback hardware and other questions for VHS to DVD conversionBy maeks84 in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 13:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
