i have an .avi at 25 fps which i want to re encode to .avi 29.97?
is their a program to help do this?
You should avoid changing the frame rate if at all possible. If you are making a DVD encode at 25 fps progressive with a 720x480 frame size. Then use DgPulldown to add 25->29.97 fps pulldown flags.
Best program to use to encode subtitled vid
By enrell in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2012, 13:58 -
Error message when trying to encode one file using AVStoDVD Program
By spritely in forum Video ConversionReplies: 3Last Post: 25th May 2011, 11:52 -
no audio from transport/program stream file when i try to encode
By uptonm in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2010, 10:41 -
Best program to re-encode XviD files to make them smaller?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2008, 22:32 -
Is there a good simple program to encode .avi's to mpeg?
By modartist in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2007, 20:35
