OK, here goes, I really hope someone can help. I have read so much online about how this proces is so easy and works flawlessly on the mac... not for me!
First off I do know and understand the process in which VHS is imported into Imovie, my problem is that its not working.
I am using the ADS Tech Pyro Av Link as the av to dv bridge. Its connected to my eMac G4 running OS 10.3.9, both of which are compatible with the Pyro.
Heres the problem: Imovie see's the connection, the Pyro does what it's supposed to do as far as switching from digital to analog mode upon import, but with all VHS tapes I have tried after 2 seconds of Importing it gets stuck on a frame, the audio starts going crazy and sometimes Imovie either loses the connection or says No Camera found. All this while the tape continues to play in the VCR, so at some point Imovie loses it. I also tried a program called Vidi, if you search for it you'll find it, This actually worked on the first tape I tried, a very neat application, saves directly to a dv file. I thought I was all set, none worked after that, it does the same thing as Imovie
The VCR I'm using has auto tracking but no manual tracking buttons, Could it be that the tracking is bad on the tapes and therefore causing Imovie to not import?
I have tons of VHS tapes and I really want this process to work. I have everything I need to do it. I am extremely frustrated that this isn't working for me, seems as though it's just my luck.
I don't think its a hardware issue as I have no problems using Imovie with my digital video camera imports.
Any Info would be greatly appreciated.
Also if anyone is familiar with the Pyro AV Link, I'm curious what your dip-switches on the back of the unit are set at. I have read many threads with different settings and I also read the the manual for the Pyro had incorrect settings printed.
	"Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	thanks case,
 try this instead then:
 http://tinyurl.com/cq4jgc"Everyone has to learn, so that they can one day teach."
 Urban Mac User
  ADS Pyro A/V Link - Firmware u/g to fix VHS dropped framesBy pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 23:40
  ADS Pyro A/V Link - black screenBy Brad in forum Capturing and VCRReplies: 10Last Post: 20th Oct 2010, 20:23
  vhs-dvd burner-imovieBy shard in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 13:20
  Pyro A/V Link w/Elements not recognised by Vista 32bitBy hhhgamewmx7 in forum Capturing and VCRReplies: 12Last Post: 1st May 2008, 20:51
  Component video capture with PYRO A /V Link?By theinv in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2007, 18:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
