hi, i have a PANASONIC AG-5210 and need to purchase an adapter to hook it up to a regular TV. I've been searching around and can't find this item; possibly i'm not using the correct search terms. if someone can post a link I'd appreciate it
thanks....
You just need a BNC to RCA adapter. If you can't find one at Radio Shack, then look here:
http://www.markertek.com/SearchProduct.asp?item=B-PF&off=21&sort=prod&skuonly=0&search...er&pagesize=20 -
thanks alot! is this what you're referring to?
http://cgi.ebay.com/BNC-male-plug-to-RCA-female-socket-adaptor-connector_W0QQitemZ2803...3A1%7C294%3A50 -
Yep, thats what I use on my own AG-5710. Available at any audio/video/electronics specialty store.
Confirming what orsetto posted -- in case that markertek.com link doesn't work, the item listed on ebay is the same. The adapter is less than a buck, but if you get it online, you'll have to add shipping. Check around at local electronics stores in your area first.
I've got several of those adapters, but can't remember where I got them.
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 06:10 -
Sharp XA-series "Professional" VCR's ... any good?
By jbd5010 in forum Capturing and VCRReplies: 1Last Post: 15th Apr 2023, 21:52 -
VCR Question
By willmington in forum Newbie / General discussionsReplies: 11Last Post: 15th Jun 2011, 15:06 -
Buying a professional or semi-professional camcorder
By besimky in forum Newbie / General discussionsReplies: 8Last Post: 2nd Mar 2010, 17:21 -
OEM OFFICE 2003 Professional question
By yogart in forum ComputerReplies: 13Last Post: 5th Feb 2010, 08:05
