I am thinking of building a Media PC, mainly to record TV, play music etc. If I build a SFF PC I am presuming that I would just need to purchase is a PCI TV card and connect the Freeview aerial to this?
Is there a particular TV card that someone can recommend through personal use, I have seen past reviews and they usually get slated because the EPG is either too slow or just generally poor. Can you use other 3rd party software with a TV card? if so what would you recommend? I am planning on using either XP Pro 32bit or Vista Home Premium 32bit as the operating system and would like to save my video files as Mpeg 2.
I have used a Pinnacle Capture card for several years to transfer VHS to DVD with much success on my main PC. I could put this in the SFF PC and connect the aerial to a cheap freeview box if I had to but the Pinnacle Studio 11 software only allows me to view what is played into it in a small window with no option to increase the screen size.
Gday,
I use a pinnacle twin HD PCI card for recording of HDTV on the pc to .TS format using Pinnacle TV Pro but can be saved to a wide number of formats using version 4.9.4. I couldn't be happier with it, works better than most other software I have tried.
James.
Homeplugs Advice needed
By iCaptainChaos in forum Newbie / General discussionsReplies: 3Last Post: 13th Apr 2012, 08:35 -
AVIAddXSubs advice needed
By betalb2008 in forum SubtitleReplies: 4Last Post: 25th Jul 2009, 20:55 -
Streamclip 1.9.1 - some advice needed please
By shoosh in forum MacReplies: 7Last Post: 13th Jun 2008, 19:09 -
Software advice needed
By ccm in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 13:01 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
