Hi,
I have some clips shooted in 16:9 with a mini dv camera and I'd like to encode them as 4:3 letterboxed.
No problem for that.
I use TmpgEnc Xpress to do the encode, the "problem" is that tmpgenc detectes all the avis as 4:3 instead of 16:9. I just have to change the source format in the source clip settings but what's the différence between these 2 options:
* Display 16:9
* Pixel 16:11 (PAL 16:9)
When I choose one or other, I don't see any difference in the preview. So I think I can use any one ???
For your source there is little difference.
If your source wasn't 720x576 there would be a difference. "16:9 Display" means the video, regardless of the frame size should be displayed as 16:9. The "Pixel 16:11 (PAL 16:9)" setting means the aspect of individual pixels is 16:11. When the frame size is 720x576 with 16:11 pixels the display aspect ratio is 16:9. (Actually the 16:9 image is held in a 704x576 portion of the 720x576 frame. There are 8 pixels of border at the left and right edges to bring the frame width up to 720.)
SAR * PAR = DAR
(704/576) * (16/11) = 1.778 = 16/9
If your source had black bars top and bottom (a 2.35:1 movie for example), and you trimmed them off before sending the video to TMPGEnc, you would have to use the 16:11 PAR setting to maintain the proper 2.35:1 DAR (ie, the remaining pixels are still the same shape as they were before). If you used the 16:9 DAR setting the final video would play 16:9, not 2.35:1. -
My source was filmed with a mini dv camera set in 16:9 mode.
The is no black border on left and right sides.
here is what gspod said:
That doesn't matter. Camcorders often continue the image out to the edges. Otherwise, people would think there's something wrong with the camcorder. The 16:9 frame is still contained the inner 704x576 portion.Originally Posted by cd090580
It doesn't matter which you use. They are both the same in your case. Because a 720x576 frame with 16:11 pixels is by definition 16:9 DAR.
PAL mini DV tape in NTSC camera
By Berghof in forum Newbie / General discussionsReplies: 16Last Post: 6th Feb 2025, 09:02 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 18:01 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
DVD TO DivX (PAL 720x576 16:9 Letterboxed)
By SamFisher in forum DVD RippingReplies: 16Last Post: 10th Jul 2007, 20:17
