Hi,
This is my first post. I have downloaded some 6 volumes education dvd video(6 dvds) and want to burn all the movies in one single or two DVD rather than burning on 6 dvds.(with or without menu) . Total size is around 7GB.
If any one know how to burn multiple dvd movies in single dvd please help me.
Thanks in advance.
Jedy
DVD Shrink in the reauthoring mode(you will lose the menus).
http://dvdshrink.info/compilation.php -
If it were me, I would use
1. DVDFab HD Decrypter to rip the discs if protected, otherwise skip straight to step 2
2. VOB2MPG to extract the titles into single MPG files
3. Re-author to creaye a new disc with menus using any good authoring tool
4. Burn to Verbatim +R DL disc with Imgburn or
5. DVD Rebuilder to re-encode to fit a DVD SL disc and burn with ImgburnRead my blog here.
thanks for the info guys..
i will try both options and let u know the result
Burn Multiple ISO's to one DVD with Menu
By AHWagner in forum Authoring (DVD)Replies: 10Last Post: 4th Jul 2011, 19:54 -
choice: burn to single BD, or multiple movies in 264?
By jlm86 in forum Blu-ray RippingReplies: 15Last Post: 20th Feb 2011, 21:14 -
900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?
By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 04:16 -
Multiple avi movies on one dvd......portable dvd player that plays it?
By 9tinyfingaz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Jul 2009, 04:56 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 09:40
