I use handbrake, but is there anything out there that is more advanced like staxrip? my goal is to encode h.264 small. Handbrake gets it done, but its rather complicated and isn't really meant to chop a file down to size, and staxrip can mux the end products together.
I use mkvtoolnix for the muxing process, same as staxrip, except not automated.
A-ha! Subtitles.
ffmpegX will take the ripped file and embed a ".srt" subtitle file.
ViddyUp does the same but will convert it to H264 at the same time.
There are a few other Mac apps that will embed the subtitles (even ".sub" type) during the transcoding process. I'm not at my normal Mac right now but will post again with a few more choices for you later tonight. -
RoadMovie will also embed subtitles (in a number of formats). Find it here:
http://www.bitfield.se/roadmovie/
I haven't used it (yet) so I can't tell you how well it works. -
Thanks, AVIdemux is still pretty buggy on mac. Ill try some of these out, but as of now, Ive figured that if I get the external sub file, i can just use mkvmerge to merge it after I encode with handbrake, the real problem was that I was losing the texts used in the subtitle file when I muxed it after a handbrake encode. But I have figured out how to add the text styles as mime's so that It picks the whole thing up. thanks for all these great programs
Played with RoadMovie. Does a bangup job with subtitles and even can simply add the subtitles without re-encoding(!); it just "flattens" the file and does it quite quickly.
The developer also has another app named "Submerge" which (if I understand correctly) just does the "merge & flatten" without any transcoding.
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
ANYDVD HD Substitute
By pandemonium in forum Blu-ray RippingReplies: 11Last Post: 8th Jan 2012, 21:16 -
Substitute to Streamtransport !
By augustya in forum Software PlayingReplies: 9Last Post: 15th Jul 2011, 12:30 -
iuvcr substitute
By marcolisi in forum Capturing and VCRReplies: 1Last Post: 4th Aug 2010, 13:50 -
Vista - TweakUI substitute?
By Ai Haibara in forum ComputerReplies: 3Last Post: 29th Jul 2008, 04:04
