A few minutes ago, my computer decided to shut itself off out of nowhere, then i started hearing this series of beeps coming from the APC surge adapter with the green light turining on and off.
How dod this happen?
You may have gotten a major power surge, or your surge protector failed.
Were you able to get the PC running again? Some surge protectors self destruct when they get a surge, but usually they have a red light in that case. Not really familiar with APC. My Uninterruptible Power Supply beeps when it loses power from the AC line. But it switches over to battery backup power then.
I would check the APC site and see if they will tell you the meaning of the flashing lights. http://www.apcguard.com/default.asp
What's the model of your APC? Other's here may have the same unit and be able to give better advice. -
No i haven't been able to turn it back on, and everything else in the house is working fine so it couldnl't have been a power surge.
Get a cheap power board with spike filtering to test pc is fine.
Common faults with apc units are battery failure and the reset power switch in the back burnt out ... its usually cheaper to replace the unit then to pay for repairs / replacement parts.
Surge Protector and Analog Antenna
By prayami in forum DVB / IPTVReplies: 4Last Post: 18th Dec 2013, 00:28 -
Home Theater Surge Protector
By carlos28355 in forum Off topicReplies: 2Last Post: 19th Jul 2011, 09:22 -
Power/Electricity setup - UPS, Surge protector, line conditioner...
By Anonymous4 in forum ComputerReplies: 18Last Post: 22nd Sep 2008, 17:43 -
Little Button on the Surge Protector
By kerrex_2006 in forum Newbie / General discussionsReplies: 8Last Post: 22nd Nov 2007, 12:19 -
Power surge protector
By toneystone in forum RestorationReplies: 13Last Post: 28th May 2007, 03:46
