I've been searching the forums, but I see more topics about people converting TO flv. Or just problems with specific programs.
I have 3 FLV files that I'd like to edit, so converting them to Quicktime or AVI would be nice.
So far, I've tried After Effects, Handbrake and MpegStreamClip. None would import the FLV files.
Can anyone recommend a good (free?) program that won't infect my computer with junk?
-M
You might be able to use FLV Extract to demux the video and audio streams - FLV Extract demuxed a VP6 AVI-format video stream and MP3 audio stream from the original FLVs, but I'm not sure what it does with the newer-format FLVs. Also, you may be able to use AVIDemux (not sure) or WinFF (or other ffmpeg/mencoder GUIs) to convert FLVs to another format.
I'd try the demuxing route, first, though, because FLV quality often isn't that great, in my experience, and any extra re-encoding (if it isn't absolutely necessary) can incur quality hits.If cameras add ten pounds, why would people want to eat them? -
Thanks!
Okay, I just tried FLV Extract. It gave me AVI and MP3 files. The audio Mp3s are fine, but the videos are all black. Maybe I don't have the right codec installed?
Not sure what VP6 means.
I'll try one of your other suggestions next. -
VP6 is a video codec, yes. You may indeed need to install a codec capable of playing VP6. If you have ffdshow installed, you can just enable VP6/VP7/FLV support in the Codecs options.Originally Posted by sky captainIf cameras add ten pounds, why would people want to eat them?
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Quicktime to flv convert with ffmpeg
By ades567 in forum Video ConversionReplies: 2Last Post: 27th Jul 2009, 09:41 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 01:14 -
Best program to convert Youtube to Quicktime
By Soccerman77 in forum Video ConversionReplies: 2Last Post: 24th Oct 2007, 03:53 -
trying to convert from quicktime to FLV using ffmpegX
By gokes in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2007, 11:03
