For some reason, when i try capturing with this proggy... i get this message:
The actual framerate is higher then the one you requested. Your capture hardware/software does not support your requested format. Check your capture hardware manual for valid settings.
Now my settings are allright. 29.97 fps, blah blah... cuz earlier today, i actually capped 40 mins (the limit with the trial) without incident. But now this evening, after 2 mins, i get this msg... plz help. I need to use this proggy cuz of the "Show drops as full frames" option, cuz i cnat find it in VDub.
Ty in advance.
By default AVI_IO has a framerate of 15 fps, this could be your problem.
Go into Capture Settings and setup your framerate, target drive, resolution etc. and save the settings as an INI file. Next time you start up AVI_IO you may have to load the INI file to setup the program correctly.
Hope this helps,
Ronin2
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 21:43 -
Megui vob to x264 giving some error in log........help plz
By crb119 in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2009, 17:15 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 17:52
